Bravia HX850 successor -W900A with Quantum Dot !
Today i had a brief demo of the W900(thats right),W800,W700 in Sony world Infantry road.:)
The W900 is available in 55" and costs 2.2lakh.
The W900 looked better in pretty much all parameters colors ,contrast and it appeared it has a better image processing even though they are advertised has X-reality PRO.That TriLuminos colors just makes colors POP out especially with their TriLuminos Demo disc,i haven't seen such beautiful deep colors in any display you have to see it to believe it.Its a worthy successor to the HX850.:)
Only the W900 and W800 have a MotionFlow setting control and none of the other Sony lcds have the setting.
Which means 46W900 could be priced close to 1.4L. Much beyond the budget for most 46in buyers. Too bad. Seems plasma is the way to go.
I was hoping for more like 1.3 lacs or else would buy w800a or samsung 7 series
Just now seen the new review at whathifi.com on the panny TX-L47DT65B.
A promising set it appears. First time a panny led earns 5 stars.
The review is putting the set on par with sammy f7 in PQ.
This year seems to be very good for both leds and plasmas which are scaling new hights in PQ.
The surprise though is from Sony, giving a 47 inch stunner w800a at just 99k!!!:clapping:
Did we ever hear earlier that Sony gave a top-line set for so cheap a price???
Now that w800a has set a very high standard for me, I am just thinking how far more will the w900 push the PQ bar!! .
This is very important, as one should see a quantum difference w.r.t w800 to put an extra 40k for this quantum tri-luminous set!
The factory setting on the W700 is so bad,adjust the settings and then check it out.It was comparable to samsung F6xxx LED.
