Just bought Yamaha YHT-299
Recently bought yht299
First time user of a ht
Havng tough time connecting it to my tv lg47lb 5610
Need to connect my ht with apple tv and stb.
Plz help
Today myself and FM @neoonwheels brought two from reliance digital.
We got two for 70.5K with two years extended warranty.
Delivery tomorrow. :)
Asking for cable as the setting up task is cumbersome and with upgrade planned in next year or so (for fronts) dont want to keep in mind bugging the cable thing for quality ! :)
Hello Everyone,
I am new to this forum.after reading threads i got very much confused between yamaha yht 299 and sony ht m5. particularly i am a music fan i will be using mostly for music and i am bass head too.
so can you please suggest me for which one i go.:sad:
thanks in advance.
Hello Everyone,
As i am new here.i am going to buy a new htib and after reading threads i got confused basically my choice is between yamaha yht 299 and sony ht-m5. particularly i am going to use for music so i need a good sound and i am pretty much bass head too.
so anyone can suggest me which should i choose or any other options can i consider.
thanks in advance
Yeh, thanks to @Vagabond, we could get a good deal. Reliance now has only 2 YHT 299 for Pune district until next stock arrives :)
Help ME.!
Between yamaha ymt 299 and sony ht-m5 which should i consider.?
or any suggestions you can give.
specially listening for music and have good bass.
Congrats ! From which Reliance Digital Pune did you buy it ? You got it at a really good price !:licklips:
Friends,
How to get clear reception in FM radio ?
Supplied wire is short. Any way to improve reception ?
Guys,
I did use YPAO to set the up my system (As of now only 3.1 config since I am yet to mount rears). Somehow the sound coming from the center and fronts is hollow. I feel like the sound is coming from a great distance even when standing next to them.
The levels for fronts are: +3db, for center its +2db while woofer is set at -8db. The distance set by YPAO is: fronts at 12ft and center and woofer at 10.
My viewing/listening distance is 14 ft from the speakers. Also the woofer sounds a bit boomy. The woofer effect sounds echo and not tight. How should I go about setting it up?
Guys,
Hi Neonwheels,
Try to take a note of the settings in a piece of paper, Try to change the settings manually as per your taste and enjoy.
If you feel confused after changing the settings and if you feel the old settings are fine, you can always change the settings as per the YPAO calibration.
After using for a year, i was curious to change the settings as per YPAO, i do see some difference (not in the good side though). So i made few changes manually as per my taste.
Change change change and enjoy :)
Hi Sandeep, good to know that ur enjoying every bit of the Home theatre, just wanted to know how much u paid for this and from where u bought , since i am also planning to buy the same
