Bug Head Player
I want to go back for now to version 6.31. Currently installed version 6.48 doesn't have uninstall built in. Can I simply install 6.31 and will it gracefully remove previous install?
6.40 is good but very resource hungry. On my computer it's difficult to run upsampling. I remember 6.31 also as being very good and not resource hungry, so I want to revert to 6.31. Of course my fall back option is the portable Sound Quality Check Version.
Running the 6.31 install will give you a message that a more recent version is running and will exit.
Run the 6.48 installation again to uninstall the package.
You will get the "Remove" option in the second Setup screen.
Regards.
enjoying 6.24 version...it sounded best till now..will keep trying new versions as well...untill new version sounds better than 6.24.
forte of 6.24-Liquid midrange, articulate Bass, crisp Highs
Just an Observation: Can you guys check with 6.48, 1x,Galaxy 30 , avx rewrite. It sounded quite good to me. I think we need to do more trial and error with 6.48.
I have been listening to 6.49 for about half an hour in normal mode. It sounds very good.
6.48 sounded a little too bright and thin to me. 6.49 sounds very balanced.
Rajiv
I also have been listening to 6.49 all evening and it sounds sublime.
Started off with some jazz standards but eventually moved to some mellow oldies (Perry Como)
It just sounds fantastic. None of the muddle and bloat of 6.48
Looks like Hiroyuki does notice feedback from the forums and makes changes.
