rikhav
- Joined
- Mar 27, 2008
- Messages
- 2,674
- Points
- 113
You need to be more specific, than "its not working" ..., whats the error you getting, can you access moode from the PC that has the folder you are trying to add?. click start run and put \\moode and click ok....do you see bunch of folders opened ??? Can you ping moode ip from the PC that has the music folder ????
There is NO NEED to mount any drive manually, you are complicating things unnecessarily.
Why cannt you delete, I just clicked on remove on the top left corner and it removed the drive I added .. it was as simple as it can be .
Hi Sam
Trying my best to answer all your queries
Yes, I can access Moode from the pc which has the drive I want to share. Infact from that PC only I transferred some files to a pend drive connected to the Raspberry pi
Can even ping it
When I press removes, it just hangs. I can play music after wards but cant access the settings menu. SO to access settings again, I need to power off RPI and then power it on again
Then it will come to the state where the nas settings were put for the first time
I really cant understand myself whats wrong with it
I had done the settings on the windows side and RPi side exactly as you had told me to do
Still when I press save, it will hang and then I need to do the whole power off and on thing aagin
