sachu888
Hi Praveen,
did you solve the issue?
Sachin
Sachin
Sorry for the messy wires... My first DIY.. so please excuse me..
https://plus.google.com/photos/106182127777309886869/albums/5824808512080844609?banner=pwa
Batteries are proper, +V to G shows voltage, -V to G is not showing any voltage.
Is this same?i HAVE SETUP THE CIRCUIT AND INTEGRATED IT TO MY AMP. BUT I AM UNABLE TO CONNECT MY VOLUME POT AS I DONT KNOW WHICH PIN TO CONNECT TO WHAT. UPLOADING A PIC OF MY VOLUME POT
pLEASE HELP ME OUT WITH THE CONNECTION
I am talking about SSP board. There are feedback resistors 10K and 8.2K, replace that 8.2K to 10K. Also on B1 board where you are shorting L1, R1 position, instead of copper jumper use 10K resistor which will reduce selectable range of LSA to 1/2 and compensating extra gain of SSP.omishra,
I have a situation where I have connected SSP to B1. Since I have connected the lightspeed LDR volume control to the Pass B1, I don't want to connect a pot to the SSP. It doesn't make sense having two volume controls. What can I do to reduce the gain if I have to supply the full signal to the SSP input?
Hi Sachin,
I am trying to fix my Norge 1000 amp and request your help for the SSP kit. As suggested kindly by Murali, I will also have to arrange for a single to dual soic8 adapter to use the LME49990s for the opamp. Please help. I will send a PM to you..
Laksh
