Is E6 the best LED that Panasonic has ever produced?
Ohh, another important question : did you get 3-years warranty with it ?
sure will do a mini-review with pictures :) ( Update: on weekends )
3-year thing is still in confusion, as i have made the payment early to get this ( last date was 15th) but i received my final bills of later dates. will clear it with the company and update here.
a quick question, how to save my custom picture settings ?
every-time i change source or switch off tv, all setting going back to default :(
this include picture as well as sound setting..
I've never heard of that. Custom settings are saved automatically. Seems like it's getting reset everytime. Check the manual.
yes its resetting everything :(
even if im not changing the source, picture setting is going back to dynamic in approx 30 minute.
nothing mentioned in 8-page manual
There you go. Thanks a lot, Naturelover. We get that settings when we reset and set up. So do it, Netant.
See post 159 on page 16 of this thread.
I figured out the setting:D
I put the reset picture in the shop demo to OFF.
Restarted and was asked if the setting is HOME or SHOP.
Selected HOME and all is well.:)
thanks mate,
I have called pana customer care right after seeing @anubisX's reply #243, the executive was also clueless about DT60. So i suspect some setting problem & have re-setted the TV to factory default, then received an option to select "Home" or "Outdoor" after language/ country setting.
for logical reason, i selected "Home" i hope this will fix the issue.
might be the the guy who came to install, selected outdoor-mode by mistake.
i can't check the TV right now, but will confirm tomorrow.
Thank you guys :cheers:
Will wait for you to confirm that and also will wait for the review (incl. 3D) along with pics. I might be getting it too if ST60 doesn't show up in their shipment.
Talked to Panasonic, they don't even have any LED above 32" now !! WTF !!
I have been telling you for some time now, that start making noise and escalate. These guys don't have stock for most of the models and god only knows what stock is coming. Until and unless you do not make noise and escalate they will just keep sitting on it.
Better escalate and wake them up otherwise i don't see anything happening this year at least.
How do i connect my 2.1 speaker system to the TV? My speaker system has just a 3.5mm jack whereas the E6d has something else (i dont know what)
There are no 3.5mm jack in the TV, there's S/PDIF (optical) and RCA for audio. There are converters available which you can use.
Here : 2 RCA Male to 3.5MM 1 Stereo Female Audio Cable 2RCA | eBay
Here : 3.5 MM Stereo FEMALE to 2 RCA Male Audio Cable, 1.5 Meter Awesome Quality | eBay
Here : Specialised Cable Stereo 3.5mm Female to 2RCA Male 100% Pure Copper Audio Cable | eBay
I see, thanks for the info.
1 question - why is there huge price difference between cables? For a INR 4k 2.1 speaker system, does it make significant difference between audio quality if i choose the INR329 cable over INR59 one?
yes, can make a fairly perceptible difference for some people, esp. for cables with still higher difference in price and quality.
Yes, that does make difference in sound quality. Cheaper one might get rust and what not. The higher price one is gold plated and pure copper so better connectivity and conductivity. And no rust.
You might be using that with a 4K speaker but you're also connecting that to an expensive TV too.
was out of city. returned today. shall post pic + my thoughts tonight :)
Hi All,
Pls do share the Standard Picture mode setting for LED Tv's , which you feel is giving good Picture quality.
