LG 2016 OLED Owner's Discussion
I have lip sync issues with TataSky on my C7 while the inbuilt apps for Amazon Prime and Netflix works fine. Yet to test a movie on my Oppo so can't say for the UDP player.
I have plugged TataSky directly into the TV as well as have tried routing it via UDP 203. The sync issue persists.
Anyone else have the issues and if yes, how to fix it? I am playing using TV's speakers.
you tried a different hdmi cable? worth a try also trying doing a factory reset on the tatasky stb, you got he 4k or hd stb?
Cheers.
I have tried two cables so far including the one which I had been using with my older TV. Assuming my older TV didn't really need to a whole lot of video processing unlike the C7, it may be a reason. The other one I have tried is an Amazon Basics cable (a 25 ft high speed HDMI) and it showed no improvement. I would assume an Amazon Basics cable should be a decent one as I am really not a believer of expensive HDMI cables.
I have the HD setup box. Would that be making a difference with this TV?
I saw the New LG C7 today and it was awesome. I wanted to know what is the difference between B6 and C7. They quoted Rs. 2.16Lacs for C7, around 1.80Lacs for B6. Is there any noticeable difference, if so is it worth the price? They didn't have B6 on display. Also did anyone get a lower price quote for C7 from anywhere else? I'm going to buy it so I want to be sure.
Sent from my ONEPLUS A3003 using Tapatalk
C7 picture is improvement over B6. C7 has sharper and brighter picture that is noticeable in actual content not just demo. If you can get C7 at a good price go for it.
try factory reset on the stb that might help.
First before doing anything try a shorter HDMI cable, preferably the one that came in DTH box. Then Factory reset on DTH, if that fails also then try Av sync adjustment settings in Tv sound settings.
The price difference is around $500. It's already down for >$1000 from the MRP. These are US dollars converted from Indian Rupee. C7 will cost around $3200 now. I could get an AVR for the $500 I save.
Oh yes, you could do that as well if you need more components.
Yes, that is what I have gone back to. Let me try switching cables a few more time or else I will do the DTH fatory reset.
LG TVs are known to have lip-sync issues when they are new to the market usually fixed with a firmware update. Try adjusting the options other have stated else best is to log a service request with LG. Hope it gets resolved for you soon.
what u mean by LG logo? do you mean the tv OSD Menu? any pics you can share? also you got the B6 or E6?
Cheers.
Its b6 lg logi and plants, earth etc in the lg trailer wad burned in its visible on warm colours, likr read orange etc
The company is now reafy to offer me your panel replacement or e6 or c7. Both comes at 2.8l from what i see in the forum they are taking max i believe. I fear if i go for panel replacement i might get refurbished panel. Plz enlighten. Any help would be appreciated.
Just info for you, UDP-205 had lip sync issues through HDMI input. They corrected this through a firmware update. Check and see if 203 has a similar issue and requires an update. I suggest you read and constantly watch the 203 owners' thread at AVSForum.
There is no refurbished panel in OLED as far as I know. As long as it gives you the picture it promises to deliver, I don't think you should worry. But make sure you are covered for all the four years of warranty available.
If you are a gamer get C7. If you love 3D get E6.
B7 should have same picture quality as C7 so worth waiting as its due for launch and already showing in LG India site. May cost even cheaper than B6!
My C7 is coming today. B7 is exactly same as C7 besides some cosmetic differences and I don't like the silver edge on that, I prefer C7's black bezels. I'm HAPPY!!
This is the time to get these OLEDs! Due to upcoming GST implementation in India, the stores (I know about LG only, samsung store which I visited has suspended billing till 1st) are emptying their stocks as they would suffer a loss for current items in stock(idk why or how). That's why they are selling these for almost the same price they bought them for. So basically the rates will be back to high numbers after 1st July. So GO BUY THEM NOW IF YOU ARE PLANNING TO!
Two reasons to pick it up now - loss of excise benefits as the transition rules allow for compensating only 60% of excise tax credits & the fact that it will sit in a higher tax bracket post GST.
I could see no good reason coming up for the rest of the year which I don't have already so I took the plunge :)
I also thought so but my LG contact is delaying this telling it has to be billed under GST and hence taking time updating their Systems
Try another LG store, you will be paying nearly 1L more after 30th June, probably. I too went to a store in another city to cross check whether my local store was genuine or not.
I am sourcing a seconds unit directly from LG at heavy discount so unfortunately don't have that option.
LG stores has never been able to get me good discount anyway.
