Marantz PM5005 or NAD D 3020 for Wharfedale Diamond 220?
peacemaker
Uttarkashi
Hi, this is my first post.
I am thinking about getting Wharfedale Diamond 220 which is the best speaker below 200 recommended by Whathifi.
Wharfedale Diamond 220 review | What Hi-Fi?
I am trying to decide on the amp. I am thinking about Marantz PM5005 or NAD D 3020. I can ask my friend to bring a NAD D 3020 from the US, so it will cost similar to Marantz PM5005 in India.
Could you advise me which will be the better choice? How are they compared in terms of sound quality and performance?
If both might be similar in sound quality, then NAD D 3020 has the advantage of USB DAC and wireless function. I mostly listen to lossless and hi-rez audio files.
I live in a remote area so it's not easy for me to listen to them in the shop, so I can only rely on the opinions on internet.
Thanks for your kind inputs.
