new subwoofer help
You can use them with standard legs supplied with the sub. Should suffice
i have denon x4800h and dali opticon 2 mk2 can you which port on sub to use to connect to avr and also what are those 3 settings knobs on behind and optimal settings to pair with opticon 2 front left speaker
how do i set dali otpcion to small speaker i cant find any settings
I would really advise you to go through dozens of youtube about your AVR and how to install a active subwoofer. Ideally you should have done it already. It's not that difficult and you will also gain some knowledge about HT setup, AVRs and subwoofers. Then you can also experiment a little.
Also go through the AVR manual.
Woofer is in transit for now just received svs cable
The pads are used for not transferring the bass to the floor. Try it without them. If you are staying in a flat then you could add them if your neighbour or lower flat owners complain.
I live on first floor parents on ground. Will it enhance bass? Will it prrvent my tv screen from shake? Tv is on tv unit
for music in 2.1 setup lfe setup will blend giood?
