Ajay, from experience, you will not be able to arrive at the best soluton very soon.
hence my recommendation..as I have been mentioning before
, to take it as 2 separate things ie 1. Protection 2. Good power.
I assume you have 1 under control.
for 2, from what i have understood, the source and the Pre give you the best benefit out of good power .
Also the source has tendency to pollute the rest of the chain the most and also gets impacted by power quality the most.
So Even If you do get an isolation tfr, just give it to the source/pre and let the power be as it is today. My guess is you will already have seen a great benefit.
you can play around with the Pre in terms of after and before the transformer as to what gives you better benefits.
I have been trying to figure this out for a very long time myself..my approach due to lack of too much tech knowledge has been purely from an audio point of view and have arrived at the above conclusion as regenerated/pure sine wave as the best solution for the Source ( its load does not vary much hence no issues of impact of Dynamics here). something I could corroborate on my system as well.
( i believe The pre has the maximum gain ,even more than a power amp,hence the quality of power being more important )
In my setup , my amp shows the minimum impact to power cables hence it is the last component i would worry from this point of view.
the best thing you can do to your setup is give it a separate line from the main transformer and dedicate it to audio...
