sam9s
- Joined
- Aug 25, 2009
- Messages
- 5,238
- Points
- 113
Step 2: Convert total wattage in to VA using formula: Total Watts x 1.67
2000 W x 1.67 = 3340 VA
I do it differently.........
Just for the informatio sake.....
as we all know VA stands for volt amper.....
In AC the volts and amps are not always in phase, the peak of voltage curve and the current curve are not always same................So in AC, if the volts and amps are not in phase you have to calculate the watts by multiplying the volts into amps at each moment in time and take the average over time. The ratio between the VA and Watts is called the power factor PF.........so
VAPF = Watts
How do we find PF....
High end electronic equipment are Power Factor corrected where it usually more than 90%, where VA simply becomes almost equalt to Watts. But general home equipment the PF as a thumb rule is taken to be 60%....so the formulla becomes,,,
VA x 0.6 = WATT
VA = WATT/0.6
VA = 2000/0.6 = 3333
Which is what santhosh also has calculate above.......
