Toshiba U79 and U80 Owners Discussion And Review !!
I am on this threads page #5. Last weekend my Mi tv 4 55" had issues with its panel. Service center quoting 36k for replacement. Instead buying new tv. As of now shortlisted LG 55" smart tv (50k on amazon) and landed on thread. Dolby vision and atmos are tempting me to get this. Available on reliance digitalfor 48k (U79) model. Product page says 3 years warranty, can anyone confirm?
I have Shield 2015 version, Xbox one X, Plex Pass, Ps4 pro and Yamaha YHT 299 htib.
60% uses normal tata sky tv uses, rest 4k movies via netflix, prime video and plex. Please suggest if this satisfies my needs, my budget is max 60k with minimum 3 years extended warranty.
Going back to thread page#5...
1st year is compressive warranty and 2 years is panel only if purchased from RD. Yes U7980 is the best at your budget
Assuming most of the buyers took extended warranty from RD, wndering whther this or the flipkart 3 year extended warranty is better.
Toshiba gives 3 years warranty on RD, but flipkart only 1 year(that's y Flipkart price is slightly less)
In RD we have to pay around 8k for 2 years additional warranty(so total 5 years) But flipkart provides complete protection at 4k for only 3 years.
I like Flipkart complete protection because it also covers physical damages too(avg. 40% compensation) and provides 30% exchange value before 3 years if exchanged in Flipkart. And for panel issues mostly it is not economical to replace, so they provide refund of 90%, 80% and 70% in 1, 2, and 3 years respectively(This is so good, so u can buy New tv within 3 years if panel fails). But Jeeves (Flipkart warranty people) services r pathetic, u should have patience and meanwhile spare tv for 1 month.
In future if Flipkart improves it's warranty services and provides 5 years complete protection for 20% tv price, then it would be awesome...
I am new Member ! I have been looking around & have found real value in the conversations !
Recently My Iffalcon 55K2A started flickering after 30 months of usage. Luckily I had 3 years extended warranty.
Jeeves Person visited & after 3-4 days declared that it is beyond repair.
They asked If I wanted refund. (Had Purchased @ 45K + 3K of extended warranty).
I said yes; they took the TV & got back 32K refund from Jeeves after 3-4 days.
Now I am Looking for 65u7980.
I have two queries.
1) I want to table mount. My table (15 Inch by 45 Inch) (37 cm x 113 cm). Will it able to hold the TV ? I was holding Iffalcon 55K2A pretty good.
2) Reliance Digital saying 3 years manufacturer warranty. Is it comprehensive ? Owners may comment !
Thanks Everyone for all the value additions.
I have two queries.
I have kept it on table and the distance between the stand on both sides is 50 inches. My table is 72 inches long and so it was an easy affair.
Thanks for the Reply ! Looks like the table won't be long enough :(.... What about the 3 years manufacturer warranty if purchased from Reliance Digital Website ... Looks like in Maharashtra Flipkart is not delivering this TV; so RD is the only option ...
I got it from Amazon and got 1 year warranty (As I missed the initial 4 days bus) but I have bought 2 years additional warranty from Amazon.
Anyone having problems getting it to connect to Wifi?
I have 2 routers. It connects fine to the wifi downstairs but that has poor signal strength. It just keeps timing out to the wifi upstairs for some reason. Both of them are running exactly the same settings so I am kinda stumped. Anyone run into this?
Almost decided to buy from Reliance Digital, Pune but they don`t have any piece on demo anywhere in their outlets. Anyone from Pune has it?
Buying without demo seems tough decision.
It's been just a week since I got 65 inch u7980 and I have already started to see a flickering line some times near the bottom of the screen about 2 inches from the bottom where the picture menu shows up. Some times a flickering line is seen across the width of the television. Has anyone else noticed it? I usually happens when there is text at the bottom of the screen either subtitles or picture menu is open. Is there a defect in the TV?
Hey, never wanted to read this one but this is clearly a common defect called out in YouTube reviews for the 65 inchers of u7980. Im assuming it's more of a software rendering thing as it's happening with menu for all. Can 55 incher guys confirm. Video at 3:00 for issue
I don't have that issue on my 55" model. However, this seems like a software rendering issue rather than a hardware one since it's happening on the same menu.
This is the exact same defect I face
His face though!
i did not face any issue like the above mentioned problem
im using the same 65inch model
