Received my 42V20 on 3rd Sep and got Tata Sky HD installed on the very next day. Must say, I am very much impressed with the HD picture quality.
I am playing HD content through my WD TV Live media player, it works like a charm. Happy with the SD quality also. :yahoo:
I have downloaded the break-in DVD and would like to get past the break-in period asap. :thumbsup:
I second that. The thirteenth generation neo pdp technology is actually resistant to image retention and does not exhibit any sort of retention at sane contrast levelspanasonic brand shop guys says that for V20 you don't need break in slides, or you dont need such kind of special care like you do with other plasmas in initial period.
^^sorry for being offtopic,but i don't think break-in has ANY relation to image retention or prevention of, in that matter.Its just all about even aging of pixels which settle at a faster pace during the early lifetime and slowly afterwards of 300 hours or so.The argument in favor is that normal TV contents are usually more oriented towards the center of the screen which sees maximum action where the corners are less worked out.Some pros do claim that they have seen varying output intensity at varying portions of the screen with a display thats not properly broken-in,but its all probably snake-oil.....or not.Its this confusion that makes people download and use break-in slides.Afterall, doing some break-in doesn't hurt whereas not doing so might.
Personally, i do break-in as the uniform aging of panel seems a valid point to me but i can easily understand someone who thinks the exact opposite way.So, each to his own.![]()
Congratulations mate, do share your experiences with us
Congrats my friend !!!!! howmuch u paid for the TV ?
Thanks Imrahn.
Frank/Chirag, I have chosen to use the break-in DVD mostly for the same reason (for uniform ageing of the phosphor). After all this is only for few days (may be weeks) and it will not harm the TV but may improve the performance on the other hand.
So no special care required ? Please confirm this, i am almost fixed on SAMSUNG LA40C630 @ 65K. I might change it and go for a panasonic plasma.Is warranty on panasonic plasmas 3yrs ?
