DIY Super Simple Preamp
Om, Sachin,
did an analysis and found out that 2 things were wrong
1. 100k and 100 ohms were interchanged
2. Volume pot was bad. Short between 2legs on one channel and second channel was open/broken.
Fixed it and tested with spare NE5532, sounds fantastic....Will be handing over the kit to Santhosh in the coming week.
cheers,
Vincent.
Om,
Sachin infact shipped a replacement opamp as well. But same symptoms. Santosh is planning to visit my place this weekend. We will try to sort it out and update.
I would like to thank Vincent from bottom of my heart for the help which he offered. He spent around 5 hours of his specially on weekend to fix the issue. Next time I will be extra careful with my DIY project.
Santosh
Santhosh,
sad that you couldnt be here. You could have learnt the tricks of the trade. Just follow the tips i gave. Will surely help you on the long run.
DIY's are meant to be learning exercises. some times costly ones :D
Santosh
Thanks Vincent for finding out the root cause of problem.Banglore,Pune members are lucky to have a great DIY commuity, no one here at Nashik:mad:
Sachin
Vincent, this is great gesture. Thank you. I appreciate your efforts and acknowledge your hardworking while debugging the issue.
Long live DIY community.
Hey all.
I just got the pre amp mode done on my Norge 4242. sounds very natural and pleasing. No scratching highs or bumpy lows. Its worth a try for all into CD music.
My thanks to Murali (murali_n)and other in the form for starting up with this tread.
Hey all.
Hi Sri,
I am glad you liked the SSP.Mr. Murli told me the improvement you got over Norge pre.I sincerely thank Mr Murli for testing SSP with Norge.Norge owners can get benefit with this little preamp.
Sachin
since i had to house the PSU as well which i am waiting to get the order. I did a simple 10 bucks snack box housing temporarily for the SSP. Here it is
After seeing positive reviews,I decided to get one kit.
@Sachin-Completed the necessary steps,pls.check account & do the needful.
Hi Sachin Sir, yes, sound is phenominal... beats costlier systems.. thanks for taking this initiative.. hope this carries on...
I am inspired by your cabinet. Tomorrow I hunt for a sturdy lunchbox:):)
Just got completed the assembly. It is sounding very nice.
What is CNC phonostage is doing in the SSP thread?
I took back the SSP preamp from FM Mathew Syriac just half an hour back and that's why remembered the circuit vividly.
BTW, I don't need the SSP as I'm going the all B1 way. If anyone wants a fully assembled SSP can ping me. I even have an assembled LDR to spare.
Hi Capt I will take both
Sachin
