Pass B1
apk,
Let us find other sources also for cabinets. BTW, pls add my name to the r-core list too :)
Here is some discussion along with pictures of Magma's B1 cabinet build. Price was approx Rs 3400 per head for a 10 member group buy.
http://www.hifivision.com/diy/12016-amp-enclosures-chasis-cabinets-23.html
I do not know if Magma will take up another B1 cabinet GB. If there is enough interest (say > 5 people), then I can PM him about this
You can even buy locally available metal cab(Rs 150) and put Aluminium/Black Acrlic faceplate like Omishra/Vin_eme did for B1/SSP.
Link for Vincent's cab http://www.hifivision.com/diy/27074-diy-super-simple-preamp-23.html
Sachin
Final List:
1.TheCoolestOne(2 kits)
2.Sann
3.Svaze (+extra Power supply kit)
4.ruenigma
5.denom
6.Murli N.
7.Santy
8.Atharva
9.NGD
10.Hemantwaghe
11.Vikoma
12.apk
13.keith_correa (+extra Power supply kit)
14.Srinisunder
15.G0bble
Sachin
apk,
Added to r-core list (post #1007).
Yes....we should explore other options for cabinets as well. Sachin has given one more option. We can also think of options from e-bay. I remember Audiodoc getting some cool cabinets from Taiwan.
You have given the design or magma did it ?
I gave my requirement. Magma had sent the side panels without the embedded 'T' nuts to screw in the bolts to fix them on to the cabinets. I tried fixing some nuts using Araldite, M Seal and the likes but the moment I try to fix the cabinet by turning in the bolts, the nuts pop out. Hope I was able to clarify.
not yet decided which cabinet - magma's, ebay, local etc
The most cost effective cabinet I thought about, which I discussed with Srinisundar also this evening is, to go for run-of-the-mill cabinets that can be found at places like Richie Street at Chennai, Lamington Road in Mumbai, Lajpat Market in Delhi which can be had for less than 300 bucks. Stick 3-4 mm plywood on the underside of the cabinet to stiffen them. Junk the face plate and make one with Acrylic or Aluminum and you would have a decent cabinet that can even adorn your living room. The total cost should not exceed a grand or thereabouts.
Adding to the interest list for r-core (thru Om's contacts) and cabinet (not yet decided which cabinet - magma's, ebay, local etc)
r-core (18-0-18)
1. APK
2. Santy
3. ruenigma
4. Hemantwagde
5. Denom
Cabinet
1. APK
2. ruenigma.
Pls add on to the list if you are interested.
APK please add my name to theR-Core and Cabinet list too.
@sahin. If you are going for a group buy then kindly send me a pair of SK 170s too. My preamp build is stuck because of these. Thanks.
I would strongly suggest locally made metal cabs with DIY Aluminium or Acrylic face plate.As Those cabs can be had in Rs 200 as Captrajesh pointed out various sources.I really like Omishra and Vin_eme's DIY low cost cabs.Cab's internal height should be min 65 mm else 15000uf caps on B1 won't fit inside.
Sachin
+1 for trafo and cabinet.
Can we get an idea of pricing for both?
If I remember correctly, the r-core should cost you less than Rs 500 (I think it was Rs 400 to be exact). Om or Sachin can pitch in here.
EDIT: Om has confirmed that the r-core should cost around Rs 650.
There are vairous options for cabinet. From whatever has been discussed so far, these seem to be options:
- cheap cabinet from local market. Replace front/back fascia. Add some re-inforcement. Should cost you around 200-300 for cabinet + a few hundreds to replace front/back faceplate. Total < Rs 1000.
- cabinet from ebay (HK & Taiwan has some good options). Cost around 50-60 USD (without shipping). You can get around $5-10 off for larger nos.
- there could be a group buy from FM bibin. He has got cabinets made for B1 and F5. Not sure of cost
- Magma's cabinet - cost around Rs 3500
I am ready to take the initiative if there are at-least 10 members interested. I will post the cost soon after completing the acrylic works. Other required hardware's like RCA, Connectors, bushes and tools like soldering iron, desoldering pump, DMM etc. i can arrange through DIYAUDIOCART.
Thanks,
Bibin
