- Joined
- Sep 23, 2007
- Messages
- 3,650
- Points
- 0
Myself for R core too
Wish to see the pic of the enclosure if available.
Here is some discussion along with pictures of Magma's B1 cabinet build. Price was approx Rs 3400 per head for a 10 member group buy.
http://www.hifivision.com/diy/12016-amp-enclosures-chasis-cabinets-23.html
I do not know if Magma will take up another B1 cabinet GB. If there is enough interest (say > 5 people), then I can PM him about this
apk,
Let us find other sources also for cabinets. BTW, pls add my name to the r-core list too![]()
Final List:
3.Svaze (+extra Power supply kit)
4.ruenigma(2 kits)
5.denom
Sachin
I think by 2 kits you mean mine and Denom's I need only one![]()
I gave my requirement. Magma had sent the side panels without the embedded 'T' nuts to screw in the bolts to fix them on to the cabinets. I tried fixing some nuts using Araldite, M Seal and the likes but the moment I try to fix the cabinet by turning in the bolts, the nuts pop out. Hope I was able to clarify.You have given the design or magma did it ?
not yet decided which cabinet - magma's, ebay, local etc
Adding to the interest list for r-core (thru Om's contacts) and cabinet (not yet decided which cabinet - magma's, ebay, local etc)
r-core (18-0-18)
1. APK
2. Santy
3. ruenigma
4. Hemantwagde
5. Denom
Cabinet
1. APK
2. ruenigma.
Pls add on to the list if you are interested.
APK please add my name to theR-Core and Cabinet list too.
@sahin. If you are going for a group buy then kindly send me a pair of SK 170s too. My preamp build is stuck because of these. Thanks.
Please add me to the xformer and cabinet list too. Thanks.
+1 for trafo and cabinet.
Can we get an idea of pricing for both?
If I remember correctly, the r-core should cost you less than Rs 500 (I think it was Rs 400 to be exact). Om or Sachin can pitch in here.
There are vairous options for cabinet. From whatever has been discussed so far, these seem to be options:
- cheap cabinet from local market. Replace front/back fascia. Add some re-inforcement. Should cost you around 200-300 for cabinet + a few hundreds to replace front/back faceplate. Total < Rs 1000.
- cabinet from ebay (HK & Taiwan has some good options). Cost around 50-60 USD (without shipping). You can get around $5-10 off for larger nos.
- there could be a group buy from FM bibin. He has got cabinets made for B1 and F5. Not sure of cost
- Magma's cabinet - cost around Rs 3500
