Tekton Moab replaced Tekton Double Impact.
Congrats. This is one hell of a speaker..
Where did you get it and what's the price?
Thanks for the update.From US, Price - $213
Have you had it shipped to India from US, if yes which site you used. Amazon.com says $303 which includes customes and shipping charges.
Got a Minidsp 2x4HD last November. Been playing around with it since then, time permitted. It's a remarkable piece of electronics. An eye-opener to the amount of control it gives you over your sound. You can literally tweak the shit out of your setup.
miniDSP 2x4 HD
Review:
Its a steep learning which I am trying hard to climb.
MaSh
My recent purchase for vibration control - soundfoundations Isopods. Felt the difference instantly! Thanks @magma for this fantastic product
I'm using it the correct way. i.e. cavity encompasses HiFi equip feet.Can thus be used both sides ?
Or the cavity goes inside the factory footers?
Correction yes, but signature I am not so sure. As of now, I feel its a really advanced EQ. But then, I am still learning to use it to its potential.With such devices & room correction software where you can actually tweak the sound to your liking & blurring the sound signatures of the different brands.
I just upgraded my speakers to fyne audio f502.
It's performance is excellent in both movies and music
Schiit Freya +
Very good one, no tube noise at all and as Transparent presentation a tube preamp can do
