Got a Minidsp 2x4HD last November. Been playing around with it since then, time permitted. It's a remarkable piece of electronics. An eye-opener to the amount of control it gives you over your sound. You can literally tweak the shit out of your setup.
miniDSP 2x4 HD
Review:
Its a steep learning which I am trying hard to climb.
MaSh
miniDSP 2x4 HD
Review:
MaSh
With such devices & room correction software where you can actually tweak the sound to your liking & blurring the sound signatures of the different brands.
It can be used either way
In fact the cavity side touching the equipment is the way to do it for speakers
It should form a vaccunm over time and will probably get latched on
Correction yes, but signature I am not so sure. As of now, I feel its a really advanced EQ. But then, I am still learning to use it to its potential.
I just upgraded my speakers to fyne audio f502.
It's performance is excellent in both movies and music
Oh, nice. Do post pics and brief initial impressions.
Schiit Freya +
Very good one, no tube noise at all and as Transparent presentation a tube preamp can do
Ahh, lovely. Do post a short comparison between this and AP tube Pre. Yeh, they are from different leagues, but still, purely Sound Signature wise?
MaSh
