deeeprider
@allajunaki...do you know if theres a wireless option for the rear speakers?
u can go to MGF Metropolitan mall Gurgaon (2nd floor) or Chittranjan park (near nehru place) ...
Any idea where is it available in Mumbai? I enquired in Croma and they're still stuck on 3100 !
I don' think so.
I had an issue with that, since the room layout is such that, we have to have the wires come through the middle of the living room. So I just wired it that way and carpeted the hall
Right now, the carpet is not big enough to cover from Sofa to the AV stand. Plans are underway for the same.
chk this review from amazon...Amazon.com: Customer Reviews: Onkyo HT-S3300 5.1-Channel Home Theater Receiver/Speaker Package (Black)this guy seems to have setup the rears on wireless using the rocketfish wireless kit. not sure if we get this India though...
Thanks mate but do u have any idea of price?
after hard negotiation gurgaon MGF mall was giving it in 25K. As i m in dwarka, i called up other showrooms in delhi they too offered 25K. I am sure they will give some discount when i visit personally.
ONKYO SIGHT & SOUND INDIA
The Box
Once you have opened the top lid, The Reciever
The Subs, Center, fronts and back speakers in another bundle within the box.
What are the dimensions of the box?
Could you post a full picture of the speaker stand (front & back)?
Surrounds on speaker stand.
Box sizes can vary: Apprx size:What are the dimensions of the box?
Length: 16, Width: 20, Depth: 29
Or
16.3 x 21.1 x 29.6 inches
Could be the standard for shipment, though!
Hi guys,
I have solved the "Boomy" woofer issue of Onkyo 3300.
Make sure u get the following settings :
Audessy : OFF
Speakers Config -> all to Large, crossover at 80Hz, double Bass: ON.
This may be upto personal preference :
Speaker Level : all at 0, except Center : -4db, Sub : +4db
A/V sync Delay : 60-70ms (!!) for my LG 42PQ60
Your personal opinion of Onkyo alone - we seem to have picked the same TV around the same time LG PQ60 in Oct - Nov 09 (just read your signature!) Hope then the tastes in audio may even match1. Your personal rating of Onkyo HTS 3300 (I am also looking at Yamaha YHT 292)
Cannot say much, since I have not auditioned the Yamaha one. However, I heard good things about Yam.
I installed it by myself. 2k for installation is on higher side. If you give me 1.5k I will come and install it for you , if u were at bengaluru . Yes, installation is quite easy, since all the wires are color coded.
