Toshiba P2305 39" Review
Plz Send your calibration settings
Anand, can you please post the settings here.
Here you go....
Picture Mode = Movie
Backlight = 10
Contrast = 90
Brightness = 50
color = 50
Tint = 0
Sharpness = 0
Contrast booster = Off
Turbo led = off
Cinema mode = on
Noise reduction = on
Color temp = no change
3d color management = on
Active backlight control = off
base color adjustment = no change
This setting is giving me crisp picture on Dishtv HD with ZERO backlight bleeding. One thing I ensured for initial 30-40 hrs is - I never ran the LED on high contrast/brightness mode, I let the breaking happen before going for calibration and now its beating my other Samsung 40" LED.
Hope this might help!
Friends, Update on the issue.
Got a call from Toshiba service center that they will b sending the new piece today.
However this happened after some follow up, but the conversations were all good with the Toshiba guys.
One thing I found not impressive is Toshiba as a company has no information on what the ticket status/issue resolution is. Its all in the hands of the service center guys.
Hi Guys, please tell me from where i can buy Dual band WLAN adapter (WLM-40U) for screen mirroring in Pune, what would be approx price?
I checked with multiple dealers but they don't have idea :sad:
Ebay.in, you wont find it in Pune
Finally got the replacement TV yesterday.
Again it looks like that's an opened piece.
Packing was perfect and at first glance it looks perfect like a new piece.
But on closer examination there are some scratches on the bezel and there is missing bezel sticker/cover on one of the edge. Told the technician about it and he promises that its a new piece. Don't know what to believe.
Please advise what to do?
Is bottom edge not having plastic cover?
Mine didn't have plastic cover only on the bottom edge. I think it is because the bottom edge has matt finish where as other 3 edges have glossy finish.
Do you see any double tapes on the packing box?
There is no plastic cover at bottom edge, rest 3 edges covered with plastic strip and whole front display also covered with think plastic paper.
Bottom edge and the right edge didnt have plastic cover.
There are no double tapes on the cover.
May be the service center sent a refurbished one?
hello friends, any one using screen mirroring? I am not able to buy WLAN adapter, please help me to locate store/online.
I didnt get any coin either. Btw you can use plethora of android dongles available on ebay. Some serve better than chromecast
OK. Checked today with the customer care, USB stick and coin offer is stopped now.
Here is a link from flipkart. Seller is WSRetail and they claim full 3 yr warranty by Toshiba.
Prices are also less there. Is that warranty really endorsed by Toshiba?
39L3300 on flipkart
39L3300 on flipkart
FK is very reliable, you can go ahead and buy it and yes the 3 warranty is provided by Toshiba.
