Toshiba P2305 39" Review
Dear Anoop Bhai,
Plz. share your experience with Infibeam as I was also liked to shop from Infebeam but due to some negative reviews I dropped the idea. I also put my discussion on 12 April 2014 in this thread here
http://www.hifivision.com/television/50766-toshiba-p2305-39-review-6.html#post584363
Plz let me know about Packaging quality, product quality (i.e. a brand new scratch free) customer support response etc...
Are you satisfied with the shopping with Infebeam and plz. share your experience with the Product in terms of features and quality...
Thanks a lot... Waiting for your reply..
Ok. Let me explain the pros first.
1) Cheapest price available for a 39inch Full HD LED TV :thumbsup:
2) Packaging was good in wooden case.
3) It was a brand new TV (May 2014). No scratch, No damage
4) 3 year warranty :thumbsup: . No other company provides 3 year warranty for an LED TV.
5) Free Wallmount installation. (Toshiba Service guy will bring the wallmount kit)
6) Watching HD movie is a treat. Quality is as better as Sony/Samsung/LG
7) USB Plays almost all video formats (AVI, MP4, MKV etc).
8) USB reads my 1TB seagate External Hard disk without any issue.
9) Customer support from Toshiba was really good. The service guy reached my home on the exact time they promised.
I placed my order on 4th May. While ordering the assured delivery date was 16th of May. Shipping was done only on 10th of May. After shipping, the assured delivery date on the courier website (gati.com) was 20th May. And I received my TV on 19th May. Cash on delivery option wasn't there and I opted for 3 months EMI.
If you can wait for 15 days after placing the order, go with infibeam.
Overall I am satisfied with Toshiba. Now I have got 39" TV for the prize of a 32" TV.
Very Thanks Sir for your kind and quick reply... But unfortunately the product is out of stock on Infibeam now...
Can anyone put a video review or just a video showing the clarity of the TV.
How is the sound quality? Or is there any link for such reviews in any of the threads, which i overlooked?
I am also having the same model and i bought the TV for full hd (1920x1080) support as dealer claimed that this led plays full HD from USB but it plays only (1080 x 720) and its not full hd :sad: does anyone having same issue as I am facing now and I must say those types of dealers who keeps their customer in dark just because of their sales productivity are so cheap and down market
Are you sure you are playing 1080x720 ? It seems odd resolution. Usually we have 1280x720 (HD or 720p) or 1920x1080 (FullHD or 1080p).
I have toshiba 39L3300 which is almost same as P2305 and it plays FullHD content fine.
Only problem is it does not support DTS audio.
Did you test 1080p file?
Sir, I have checked 1080 x 720 videos which is running perfectly but when i check for 1920 x 1080 videos, its not visible in LED or Media player of LED. so How i will solve this issue as you are saying that FullHD is running but DTS nor playable and I am playing non DTS FullHD video :sad:
anyone using speakers with this tv ? any recommendation for compatible 2.0 or 2.1 ...? budget around 1-1.5k
I am using Creative Inspire T3130 2.1 Speakers and it sounds great! I had got a great deal on FK in Oct'13 and got them at 2.2k. Now it is around 2.7k on FK.
I used analog audio out and used a Male Stereo RCA to Female 3.5mm cable (Rs.50) to connect speakers.
So buddy have you tested the same in your led and what is the result you got
Hi.. It works! :yahoo: My TV reads the file from USB and plays it very well (Both Audio and Video). Here is the file properties:
Code:
Format                         : MPEG-4
Format profile                 : Base Media
Codec ID                       : isom
File size                      : 140 MiB
Duration                       : 6mn 47s
Overall bit rate               : 2 886 Kbps
Writing application            : Lavf55.19.104
Video
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : [email protected]
Format settings, CABAC         : Yes
Format settings, ReFrames      : 3 frames
Codec ID                       : avc1
Codec ID/Info                  : Advanced Video Coding
Duration                       : 6mn 47s
Bit rate                       : 2 753 Kbps
Width                          : 1 920 pixels
Height                         : 1 080 pixels
Display aspect ratio           : 16:9
Frame rate mode                : Variable
Frame rate                     : 29.921 fps
Minimum frame rate             : 29.920 fps
Maximum frame rate             : 30.769 fps
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Bits/(Pixel*Frame)             : 0.044
Stream size                    : 134 MiB (95%)
Audio
Format                         : AAC
Format/Info                    : Advanced Audio Codec
Format profile                 : LC
Codec ID                       : 40
Duration                       : 6mn 47s
Bit rate mode                  : Constant
Bit rate                       : 126 Kbps
Channel count                  : 2 channels
Channel positions              : Front: L R
Sampling rate                  : 44.1 KHz
Compression mode               : Lossy
Delay relative to video        : 33ms
Stream size                    : 6.10 MiB (4%)
Thanks for file info. Which TV you have?
Code:
Format                         : MPEG-4
Codec ID                       : isom
File size                      : 140 MiB
Duration                       : 6mn 47s
Video
Format                         : AVC
Codec ID                       : avc1
Duration                       : 6mn 47s
Color space                    : YUV
Bit depth                      : 8 bits
Audio
Format                         : AAC
Format profile                 : LC
Codec ID                       : 40
Duration                       : 6mn 47s
Bit rate                       : 126 Kbps
Any one has tried chromecast or similar to receive FULL HD(1920x1080) streams from PC/Mobile etc...
wrt Toshiba 2305 or similar (pls mention)
TIA,Bhanu
@simplysam.singh, Yours could be an issue with the USB Disk. Have you tried with another disk?
Thank god its working in another USB which formatted with NTFS and i was trying to load the same in my USB which is in Fat32. Is there any way to run the same without changing Fat32 to NTFS because NTFS USB is not recognizable in my phone Xperia Z :indifferent14:
