Toshiba P2305 39" Review
Thank god its working in another USB which formatted with NTFS and i was trying to load the same in my USB which is in Fat32. Is there any way to run the same without changing Fat32 to NTFS because NTFS USB is not recognizable in my phone Xperia Z :indifferent14:
glad it worked :clapping: It might not be an issue with filesystem. It could be the bad sectors in your first USB (FAT32) which caused the issue here. Why don't you confirm it with converting the second one to FAT32 ?
second one???
means my another USB from which I have tested Full HD videos right???:licklips:
Which Chromecast/Miracast dongle shall make the toshiba 39p2305 the smart TV.
@tarey_g - Any inputs from you ? You had commented on the same some time back.
-Parimala
Thanks for the qwik response.
Do you think it is wise to buy Toshiba 39p2305e + Android Dongle over Toshiba 39l3300 which is semi-smart. Both come @ same cost around 39k.
Any tips you want to share to make your p2305 a smart tv.
Thanks,
parimala
Hi Guys , Recently Bought a Toshiba LED TV 39' Inch Model 39L3300 From a local dealer in Gujarat (Rajkot).TV works really good and would recommend this specific model for people who want to feast their on bigger display screen such as 39'inch.Plus I got a dongle which came along with the TV unit,the dongle is made by Toshiba itself.I have a Samsung Galaxy S4(GT-I9500) which supports Screen Mirroring function and I can see my mobile screen onto 39' inch TV I also have a Dell XPS (L502x) which has Intel Widi (Wireless display) which also I am able to connect to TV wireless.Movies in mp4 or mkv in 720p as well as 1080 p can be played flawlessly.As Laptop can Decode DTS audio i'm able to play HD movies on TV Via Dell XPS (L502x) .If interested Kindly check the below link as i have uploaded TV photos and dongle..cheers ... http://goo.gl/FuzISx If any question please feel free
Nice to have the wlan adapter from toshiba. what is the price you got tv for.
Thanks for sharing :thumbsup:
How much you pay for it...
Hi guys,
I like to buy 39p2305 toshiba tv from flipkart for my home. But the problem is, we still use local cable connection in my home town. how is the picture quality of p2035 with cable input? could somebody share images of p2035 with cable input.
Thanks in advance
Afrath
Well I got the Toshiba LED TV 39' Inch Model 39L3300 for 36k (36,000 INR) . And Everything is included in that Price,VAT + Octroi + Transportation + Installation + Toshiba Dual Band WLan Adapter + 3 Years Warranty for the Tv Set + Silver Coin (Limited Edition Signed by Sachin Tendulkar). Eveything inclived the price i paid for the local dealer at the time of buying is 36,000.I bought the Tv 1st or 2nd June 2014.
Owners, please let me know how much is the overall weight of this TV and also the Power consumption (Max Watts).
Well This Specific Model Toshiba LED TV 39' Inch Model 39L3300 Has a Power Consumption of 123 W and Standby Power Consumption of 0.4 W. As far as weight is concerned Net Weight is 7.9 Kg Just of Tv Screen . With Tv Screen and wall mount and Tv Stand total weight stands at 8.5 Kg. (WxHxD)mm 891x525x84 when wall mounted.
