Toshiba U79 and U80 Owners Discussion And Review !!
how to force firestick resolution to 4k 24fps in order to get 4k dolby vision?
I can't emphasize this enough: Don't do it. First of all, forcing 4k 24 fps is a debugging option and not a default option provided. If you play any 30 Hz, 50 or 60Hz content, it will look wrong. Also, the firestick UI will look sluggish and choppy. On top of it, you'll only get 8-bits of colour depth which will degrade the quality much more than DV will improve over HDR 10.
The only sources of DV content are Netflix and Disney+hotstar. For Netflix, you can use the inbuilt app, and Disney+hotstar will also come to the TV in a couple of months. TBH, Hotstar has such a shit bitrate that DV, HDR10 or SDR doesn't really matter as the image looks bad and blocky anyway.
If you still want to do it: On the firestick remote, press the rewind button (looks like <<) and the up simultaneously for about 10 seconds and the display will start cycling through resolutions. When it gets to 2160p 24 Hz (it will be 12th option I believe), press the select button. You're done now. To go back to the 4k 60Hz option, you can do it in display settings as usual. Also, remember to set the bit-depth back to 'up to 12 bits' there.
thanks for the help. i hope firestick will fix its issue with automatic resolution.
Using the TV with Xbox Series X and both the TV and console are great. Just a bummer DV on the TV is too old for the xbox.
Any idea when the next update for the TV is expected approximately
Was anyone able to cast their screen from their iPhone on the U79?
I have a 11 with iOS 14.2 and cant seem to get it to work.
Casting works with 2 other Android phone's in the house tho. TV FW is up to date.
Any suggestions?
I forgot to update the thread that i finally bought the 65u79 from reliance HYD few days ago and installed it myself on a standmout as of now
ive been working on the video settings for the past 2 days and i found @lightgamer recommended settings very decent to start with.
I will update the thread in the future with my final thoughts and review .
Here are the initial impressions:
decent out of the box colors
easy to setup
inbuilt media player is sub-par
OS is very responsive and quick
motion is quite poor but turning it off helps but still could be better[biggest problem with this set]
upscaling is quite good for 720p and up, 480p and below depends on bitrate. tatasky SD channels look sub-par
would recommend external streaming devices.
easy to setup
Please update on the HDR and black levels
for me the HDR performance of this set is just decent/ above average
doesnt get very bright as mentioned 700nits by the company
but on the SDR performance its stunning and gets very bright enough to overcome glare and reflections
Black levels are outstanding [major pro in this TV]
I will update the thread with my full review in few days
Anyone here brought from Bangalore? I tried calling few reliance digital showrooms here. None had display pieces to give a demo.
Please let me know if any one knows a show room in Bangalore where i can get a demo.
you can only demo in HYD for now in all of south
If anyone here finds a 65" U79 in stock in Chennai, please do mention here. I don't really care about demo, just anyone in Chennai city (or who can ship to Chennai) who has the unit in stock. Thanks in advance!
better hurry up because when i purchased, my unit was 13th remaining is hyd
now there might be less than 5-6 units in 65 inches
