spirovious
What are the power output claims of the 7.1 Yamaha RXV-677 & how much does it costs in India?
Yamaha 667 claims 90w/ch,but has only 400w power supply.Price with B/W in Mumbai is 39k & 37K in grey.
90 w/ch at what impedance rating? 4,6 or 8 ohms. Also is this figure all channels driven or only one channel driven? What are the THD levels at 90 watts & also is this power attainable through out the audio frequency spectrum or just something like mass market @ 1kHz.
It seems that you are quite confused. 400W is the maximum "electrical power" the unit can supply to the amp section. What you are talking about (mean/ nominal/ maximum ) is for the amp section. There is no nominal or average rating in power supply. This PSU can continously output 400W requirement at all times if necessary. How much power is derived from the PSU by the amp depends on the audio recording and the volume set on the AVR. However the Amp's power capabilities are limited by the PSU.are you figuring this amp have a 400 watts since it is written at the back of amp as a power consumption figure rating? If so you are mislead. Many factors go into the power ratings, that make them pretty much useless for predicting power output. In most cases we don't know the test condtions so even assuming that the back panel power is nominal, average, maximum, minimum or whatever is nothing more than a guess unless it specifically says what it is.
For your kind information, the subwoofer channel is not amplified. So you must divide by 7 and not by 8.Go by the weight of the amp. If it hovers at around 10kgs, it will have a 300VA transformer at max which will lead to 160 watts of usable power for all the 7.1 channels, ie 160/8 = 20 watts per channel with all channels driven simultaneously.![]()
Again I wonder why you have to do complicated maths to know how much maximum power each channel can handle- all continously. It is 400W / 7 = 57 w per channel. But it would never go to that extent. The AVR can output a healthy 90W whenever there is a demand. Assume you use 80W for the main channels ((fronts & centre) ie 80W x 3 = 240W and we still have a lot of power (160W) left for the surrounds.
Above all, maximum power rating is not everything. There is much more to do with the amp which defines how good the sound is. What matters is how the amp makes use of the power and not how much it uses.
I agree with you, there is a power loss in terms of heat due to inefficiency but I don't think class AB are that bad.. they must be around 75% efficient. I do not want to get into more details without sufficient knowledge. It needs more understanding especially when the 400W supply is AC and the amplifier extracts DC power!What is the weight of the amp? This figure will open all mysteries about its power output capability.
Also according to you if the power supply module of 667 is capable to deliver say 400 watts to the power amp module, there will be no heat loss and you will get 400/7 = 57 watts per channel. In other words a power amp with 100% efficiency.
Class-AB power amps have 50~55% effeciency at best & the rest 45~50% is lost as heat. This is the reason why amps get hot.
So we end up half of what you get from the power supply i.e ~210 watts at max from the speaker output terminals. Ee get 210/7 = 30 watts per channel with all channels driven. Still the light will be shown when i know the weight.
Do you have an engineering background? Just for interest. You define very well. Keep it up.:thumbsup:
@Santy one request.
You have both the Yamaha RX-V471 & Norge 1000. How do they sound in stereo mode with the same set of speakers. I mean which one do you like more to hear for music? And why?
Which amp will you call superior in terms of sound reproduction? Which amp has more power in stereo mode?
I will love to know all these details since I own a Norge 1000 too.
I agree with you, there is a power loss in terms of heat due to inefficiency but I don't think class AB are that bad.. they must be around 75% efficient. I do not want to get into more details without sufficient knowledge. It needs more understanding especially when the 400W supply is AC and the amplifier extracts DC power!![]()
However I am keen to know your formula of calculating actual power simply based on weight of the amp. The weight not just depends on the transformer but many other things inside it, especially since its not just an amp but an AVR. I also wish to know why do you think Yamaha is misleading us in giving wrong specifications??
The amplifier weighs around 10.5kg and yes I am an Engineer.
Thanks for asking. There are two things to it: the DAC and the Amp. I have not checked the AVR with the output of Caiman nor the line out of AVR on Norge. In other words, if I am purely comparing the two amps, then I should have the same source/DAC in both the tests, which I have not done so far.
Having said that, for music, the stereo setup is much much better than Yamaha eventhough the AVR is considered to be musical. However I am not sure whether the DAC or the integrated amp is the main factor for this difference. I would give a 50-50.
Eat this :
So Watts the Problem?
Gene : "I totally understand and respect the tradeoffs between amplifier power and features in budget A/V receivers. Heck just a few years ago, you couldnt get a 7.1 A/V receiver with HDMI 1.3a A/V processing and decoding for under $2k, now you can get them for under $500 with OSD support via HDMI no less. Thats progress!
What I do take issue with however is when a receiver company releases their next generation of receivers at the same price points with virtually the same operational features, but costs reduces the power supply in attempts to increase profit margins.
Lets take a look at the differences between two $549 Yamaha receivers as an example. Yamaha isnt the only brand Ive noticed this trend with mind you.
Yamaha RX-V663
Yamaha RX-V665
Yamaha RX-V663 | Yamaha RX-V665
Retail : $549 | $549
Power Spec : 95wpc x 7 full bandwidth | 90wpc x 7 at 1kHz
HDMI (I/O) : (2/1) | (4/1)
Component Video (I/O) : (3/1) | (2/1)
A/V inputs : 5 with s-video | 4 (composite only)
Digital inputs : 3 opt / 2 coax | 2 opt / 2 coax
HDMI Up conversion : Yes | to 1080p
HDMI Pass thru : No | Yes
Speaker a/b : A + B | A only
Dimensions (W x H X D) : 17 1/8 x 6 3/4 x 15 1/2 | 17 1/8 x 6 x 14 3/8
Weight : 26.2 lbs | 18.7 lbs
The upgrades for the new model (RX-V665) includes HDMI up-scaling to 1080p, HDMI pass thru to enable video when your receiver is turned off, and 2 more HDMI inputs. The downside is no s-video, one less optical input and a significantly reduction in power. When a receiver company rates their amp at 1kHz, this usually means a full bandwidth(20Hz-20kHz) measurement will be about 10-15% lower. Thus I suspect if we were comparing apples to apples, the RX-V665 would only output around 70wpc compared to the 95wpc rating of its predecessor. Of course with nearly an 8lb weight reduction and considering both receivers use linear A/B amplification, this also likely means the RX-V665 doesnt have the power reserves to drive multiple channels with as much poise and finesse as the RX-V663.
For the above example, the consumer must decide whether or not the upgraded features of the new receiver are worth the sacrifice in amplifier quality. I suppose it depends if the end user leans more towards emphasis of video features than audio. If they desire both and one day have intentions of adding external amplification, than doesnt this become a moot point?
Not always. From my testing of A/V receivers from various manufacturers, most of them simply slap preamp outputs on the back of their receivers for a marketing feature. It is a very inexpensive way to impress the unsophisticated user into being awed. They usually dont put decent op-amps that have enough output to drive external power amplification to its full potential without the internal preamp of the receiver first clipping and going into gross distortion. Remember these receivers are designed as a closed loop system to work optimally with their own internal components. If the manufacturer is cutting costs in the power supply of their product to offer you more features, its a safe bet they arent giving you a higher quality preamplification section to power an external amplifier.
Conclusion
Having done this job for some time now, Ive noticed this trend with many of the major brands over the years. Companies go through up and down cycles and as a result lose market share. As long as technology keeps evolving, manufacturers will do their best to cram in features of next generation products that were only previously found in their flagship models. While IC integration will trickle down technology, reducing production costs making it easier to achieve this, there will usually be other compromises in the lower end models to realize the feature count.
Finding that balance of basic performance compromises vs. relevant features is the equation that receiver manufacturers must figure out when launching their new platforms. It seems Yamaha has upset this delicate balance with their latest RX-Vxx5 series of receivers. We will be paying careful attention to this trend for all manufacturers during our product evaluations to recommend whether or not these new dream machines have the audio chops of their predecessors or if theyve got the tools to adequately drive external amplification for those looking for more power in their next home theater experience. Dont just run out and buy the latest model because its newer.
Stop and think if the model you currently have meets the performance vs feature balance that is right for your needs and how the newer so called improved model fits into that equation. All the features in the world cant replace clean undistorted dynamics which we believe makes up most of the WOW and magic in the newer HD audio formats."
Gene DellaSala Biography
The above content belongs to two of the Gene's articles as below:
Product Managing Receiver Platforms & Power Ratings
Trading Amplifier Quality for Features A New Trend with A/V Receivers?
Fourthly it is very clear that you are slowly trying to bring in your God Made Amplifier unfittingly into this thread which is considered to be hijacking. Please limit your halleluiah to your own thread and spare the owners of Yamaha AVR.
Finally, showing this difference in power between two models of a brand, as the main reason why an old amplifier which does not even process discrete multi channel audio is better than the new AVRs for true home theatre experience, is simply RIDICULOUS. Forget HD audio, what's a home theatre which does not have 5+1 discrete audio channels.
Anyway let the discussion please be continued in your DSP-A2070 thread and whoever wishes to hear your "old" stories will meet you there.
My 667 shows DTS on panel when a DTS disc is played.Then why when HD dts disc is played it shows STRAIGHT?Can anybody clarify?
Fourthly it is very clear that you are slowly trying to bring in your God Made Amplifier unfittingly into this thread which is considered to be hijacking. Please limit your halleluiah to your own thread and spare the owners of Yamaha AVR.![]()
You have to choose what information is to be displayed in the panel.
Three options are there in 471, not sure about 667
1. Input source
2. DSP program
3. Audio decoder.
Here is the link abt 667-
RX-V667 - AV Receivers/Amplifiers - Yamaha - UK and Ireland
Now 667 is around 10.5kg,THD-0.06%
Now I have one question.When 400w is in use,how much power will preamp & video section need?
If I assume 50w,so I should get ideally 350/5ch = 70wpc. (5.1 setup)
If we consider heat,it should pump atleast 60w around.
Yamaha certainly produces less heat than my Onkyo and also has Damping factor upto 100-120 unlike 60 in Onkyo.
I have been patiently tracking this discussion of "continuous power" for the past few days and had hoped that someone would be able to enlighten Rishi "Guruji", however it seems the discussion is being dragged without a direction, so pitching in.
Guruji - Thanks for the great pics of the interiors of Norge and 667. However, this entire discussion of continuous power is useless as neither Yamaha or any other member here claims that it will give more than your "claimed" parameter which is ENTIRELY USELESS in Audio Engineering arena. Especially SOPHISTICATED AUDIO ENGINEERING as is done on all AVRs!
You have COMPLETELY OMITTED the FACT that HUGE CAPACITORS are used to hold momentary charge needed to suffice the power supply which CAN provide more than 1000w (hypothetically as I don't know the exact figures of this AVR) of instantaneous power when needed. So most of the times, even when the unit draws in excess of 1000 watts of power (typical during extreme volume, low/high dynamic range music/noise eg from a movie action sequence). Now as many have pointed out here, chances are, you will have hearing problems if you listen to the AVR connected to a decent low impedance speakers.
Audio has NO USE of "continuous" power. What matters is the RMS power which relates well to how we PERCEIVE audio! And that 1000Watts of peak RMS power may still consume around 300Watts or even less of continuous power like you have been talking about. But that doesn't change the fact that these receivers are capable of FAITHFULLY producing those much RMS power with ultra low distortion figure of 0.06% even when all channels are driven (distortion will increase, sometimes significantly when all channels play loud sounds, but the power output will still be stable at a reasonable/typical listening situation).
I know that higher rated transformer may actually improve the AVR's performance in extreme condition significantly, but that is not a TYPICAL situation we encounter everyday and hence manufacturer decide to consider an average situation only to consider a power supply.
Now this situation change for a high end stereo amp or an expensive AVR which are built to be abused by high listening levels and typical application is high intensity music and hence your Norge amp has a relatively higher rated supply with more continuous power per channel than the AVR (typical for an AVR).
So, while I am no way trying to contradict or pin you down, you seems to be very adamant with your half cooked understanding of "electrical engineering" rather than willingness to understand the underlying thought process the design engineers had while considering a component. I hope you do find this enlightening and you would be appreciative of my advocacy here. Lets stop judging an equipment by their weights, I have never done that and will never do it while still appreciating high performance/heavy duty devices irrespective of their actual weights.
