Toshiba U79 and U80 Owners Discussion And Review !!
Thank you all for doing these reviews..and keep them coming! I had finalised 55' x950g and might have even gone for 65' x950g for close to 1.4L. but now reconsidering it..thinking of getting u7980 65inch at 66... And investing the extra for elac b6.2 and denon avr 1500h....if overwhelming opinion talks good things and if I get some idea about after sales services..might actually go for the latter option! What do you all think?
New member here. Have been a long time lurker.
I bought the 65u7980 on 21st and had it delivered day before yesterday and got it installed yesterday. Did some calibration as per rtings calibration for h8f, it improved PQ a bit.
I have a fire tv pendant ( 2017 us variant ), unfortunately it doesn't support Dolby vision, and I am at unease knowing the Dolby vision playback issue through external devices, has anyone tried an external device to playback Dolby vision through say firetv 4k or nvidea shield.
Also the video looked wierd specially when I played mad max Bluray remux via my Plex server , that's when I realized I forgot to change the bit settings on my firetv, upping that from 8bit to 10bit solved the issue. Bluray remux look insane on the tv, Dunkirk specially.
The inbuilt plex app is not that good, I ended up switching mostly to the firetv Plex app.
Here's some issue though, when I put on a totally white screen, there's a bit of shadow at the corner, like some shadow effect is this normal?
Apart from that, if I turn off local dimming completely and have a black image, at night the screen look somewhat dirty will attach pics soon.
I've googled the issue and it seems to be isolated to Xbox only. But even if it doesn't work with external boxes, you can use the internal app. Also the TV is supposed to get the VIDAA 4.0 OS in Q1, so that should fix the issue with Xbox as well as it's in Hisense's top of the line TVs(like U8QF) and they don't have any issue playing DV titles with external boxes.
That's the enhanced HDMI option, correct? I'll be setting up the TV today, so thanks for the tip.
Oh no! I was planning to use that one. I don't have an external box as of now, and I won't buy anything except Nvidia shield. I guess the fire stick 4k is okay as well, but still it's too expensive for the interface. Anyway, I'll at least give it(internal app) a chance.
This is known as vignetting. If it's only visible on pure white and quite minimal, you probably have a better panel than most folks. VA panels generally have this issue. Even Samsung's 2 lac TVs like the Q90T have it. If you think it's more than you'd like and is affecting movies and TV shows, please get it replaced. Else it's fine and quite common. You'll need either a high quality IPS panel or OLED to not get any vignetting or dirty screen effect.
That's supposed to happen and why local dimming exists. If you don't use local dimming, this TV won't be much better than cheaper TVs. Basically, local dimming has your TV in 56/60 zones of backlight for 55" and 65" version respectively. If you display pure black with local dimming, all of them will turn off the backlighting. However, if you turn local dimming off, they won't turn off and the LCD layer will have to block the light coming from behind, which it won't be able to do 100%.
Yes Getting a Good Panel is like a lottery nowadays, My 55 inch U79 also has noticeable dirty screen effect.
@lightgamer bro,you need to start a youtube channel or a review website like rtings for India. You're super knowledgeable about TVs and there is a series shortage of proper reviewers in India. Every Indian TV review is like PQ is good,sound is good and smart tv is good. Doesn't matter if it's a 30K TV or a 2 lac TV. The only reason I even bought the U79 is because someone here mentioned it was an h8f and had all the US reviews to give me an idea of what I should be expecting.
Plus one! Seriously give it a thought. You know what's funny the 2 reviewers who claim they don't run sponsered content viz. Techiebeez and VMone have never in their toshiba reviews mentioned that it is a hisense owned corp....
Does HDMI cable make a difference in video Quality ? I use a unbranded Cable from my tatasky to U7980 TV.
It's not that I haven't considered it, and I even had a tech blog 5 years ago(which is now deleted since there was some issue with monetization with it). A few of my friends also stated the same that they got more from me than a review. However, it's not so easy:
  • I have a cushy, very high paying job which requires a good amount of participation during all weekdays (8-10 hours per day). Also, I love my job a lot so leaving it is not an option. It only leaves me with weekends to do longer format content creation like a blog or article or YT video. And we all like to enjoy our weekends, so laziness plays a role here.
  • Unless you have all the time in the world, a single person operating a Youtube channel is hard work.
  • Getting review units will be a challenge, if not impossible as a small site/channel.
  • I neither have the video equipment nor the testing equipment to create the content I myself would watch. Also, I'm at my parents home till the pandemic blows over which doesn't have much space to create videos (but when I move back in 6 months this won't be an issue)
Honestly, if it was a zero money investment (just investing my time and effort), I'd have started it. And I am contemplating ideas on how to start up in a cost effective way. I don't want to spend 2+ lacs on equipment and then gain nothing back. Even if I was to make no money for 1-2 years it would be fine since I'm passionate about it, but I seriously don't want to invest a lot of money upon starting it since I'm not going to be doing it full time.
Here are the ideas I've considered:
  • Create a tech consulting website with another equally passionate person. I am a software engineer so creating a site won't be an issue. I can handle all the content and SEO and that person handles the operations (getting review units or loaners from stores, new ideas etc).
    The website will take your requirements and have an algorithm to suggest the best products for your needs. I have good knowledge of phones, PCs, tablets and TVs so can start from there. There will also be a (paid) personal consultation option.
  • Create a YT channel after the pandemic blows over. Start myself with just a phone and a basic mic (blue yeti), go to stores and ask for loaners for a couple of hours (share some profit on video with them). Eventually will start to get review units from brands as the channel grows. Can also start more sophisticated testing from there by buying equipment from the earnings.
  • Get a part-time job at a tech website/YT channel and get recognition from there. Leave in a few months and start my own thing/get equity there (least preferred option).
It's hard to start up something part time, especially alone. I'm trying to find something equally passionate about tech. He doesn't need to know as much, just be super passionate about everything tech and willing to do part-time work for some time and grow and have the same knack for perfection and be better than generic tech blogs/reviewers.
As long as your HDMI cable can transmit 4k 60 fps signal, all HDMI cables are the exact same. HDMI is a digital format and not analog, so the quality of cables do not matter. If it's inadequate, it will simply not work since it won't be made for the spec.
Long time lurker here, first time posting so excuse me if this is not the right place for my question but does anyone have any info on when this TV will be available in Delhi?
I see people here saying they have ordered it within the last 2 days when it has shown sold out on all platforms. Is the stock available only as per location?
Anyone has any news on why this might be the case?
Just want to understand how long I might have to wait as I am looking to buy a new TV for my parents and they need it within the next month.
After using the Tv for a couple of days and comparing with my Sony 42W900B side by side, I noticed the viewing angle is not that great compared to Sony which is expected for this panel, my Parent's don't want this huge TV(the main reason why I bought this) as they feel it is too bright for their eyes
I tried the TV in my room, I sit on my desk about 70 degrees from center of the tv and with only one location to place the TV, The viewing experience was not that great because of the viewing angle.
I had to again convince my parents to use this tv, reduced the backlight and made the picture warm and they are now ok with it. also they sit in the middle so viewing angle is not an issue. Now I got the Sony 42W900B in my room and it made a huge difference because of the IPS panel.
So if people want wide viewing angle or used to IPs screen or the entire family sits in different location to watch the TV, then this TV wont suit you neither the higher end Sony or any other VA panel TVs, except for the Sony X wide angle models and Samsung Q70R.
Between is it possible to slightly increase the viewing angle by playing around with the settings or will break in improve it, firstly is there a Break-in period for LED Tv's.
You could always use an articulating Wall mount to rotate your tv at the desired angle.
Hey man, did the installation guy ask for extra charge for labour for wall mounting it. I see that it's free on Amazon, but he's saying that only wall mount kit is free, labour isn't.
I know he's cheating me and he hasn't arrived yet, but would still like to confirm here that others haven't paid extra.
It should be free. There was a checkbox earlier for the Free installation but its not there now. Maybe they removed it after the 18-21st Sep period got over? I found this article on the Amazon (link also on the U7980 product page)
I understand. Having a full time job takes away a lot of your energy when you want to pursue your passions.
Initially, I think you can start off with just a simple blog or a video podcast(just have some pictures and content from elsewhere) where you share your opinions and any technical insights. I'd say YouTube is a better place to gain a following than something like a medium blog.
You can then leverage that following to get some review units from brands. I feel like quality is recognized by the Indian audience since we are lot more tech literate nowadays. Idiots like GeekyRanjit and TechnicalGuruji have gained a massive following with pretty low quality content, so I'm assuming you would have an even faster growth.
Call Hisense directly. They were very good with customer service. Installer came next day and was very professional. Didn't charge anything
Give it few days.
My tv had uneven illumination (DSE) on the top part out of the box. It vanished after nearly 4 hours of operation.
Pretty happy with the screen uniformity.
Although there is vignetting on the extreme corners, which I had noticed in H8F reviews.
